How do I copy  connected Analysis systems
    • Lee myungjun
      How do I copy  connected Analysis systems boxed with red rectangle?
      thank you,
    • Ankush Choudhary
      Hi, you can duplicate the second analysis while keeping the first.
    • SaiD
      Do you wish to duplicate these two systems? Or do you wish to copy only these two systems to a fresh project (such that the new project only has these two systems)?
      To duplicate: You can right-click on Cell 1 of System E (where "Static Structural" is written) and choose Duplicate. You then get the option to either retain the links to system D or create an independent system. Similarly, you can duplicate system D.
      If you wish to copy these two systems to a fresh project, you can use the "Export System" option from the menu that shows up when you right-click.
      Hope this helps.
    • Lee myungjun
      Thanks for your replies :)
      The problem is
      when duplicating E1 with links, then I got linked structure system to D
      ,not with links,  I got independent structure sytem.
      But I wanna know how to duplicate the entire independent system of D & E with link each other.
    • a_l_o
      You can select both systems by "box selection", so drawing a rectangle including both systems with your mouse pointer (just as the red box in your screenshot), then right click and duplicate. This way, both systems will be copied as they are, but without any links to the original ones.
      • Lee myungjun
        it works!! thank you so much sir :)
        • a_l_o
          Wonderful! :D I am female, so no sir in this case please.
        • Lee myungjun
          oh, thanks ma'am =)
Viewing 4 reply threads
