October 19, 2017 at 4:48 pm
cstark488
SubscriberHow do i simulate a delamination as an interspace or actual separation of 0.02mm between layers 3 and 4 of a carbon composite material? The delamination area is defined as 11.275x11.275mm and the centre is 163.5x163.5mm of a 225.5x225x2.05mm carbon composite plate. I have defined the area in the geometry and created it as a named selection. I am unsure what to do next, I can create the composite but I can't create the gap.
I appreciate any help.
Kind regards,
Callum
- Invalid Assignment error
- How do I make a chart with multiple material parameters on y-axis?
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- ANSYS 19.0 with Additive Manufacturing Extension
- How to add SN curve for new material in Fatigue analysis?
- Looking for Spring steel (55Si7) library material
- properties of balsa wood
- Ansys material damage
2616
2098
1323
1108
461
