Tagged: academic, ansys-student, cad, multiple-bodies, static-structural
March 23, 2022 at 3:09 am
malorengo
SubscriberHello, in Ansys Mechanical I am trying to design parts as individual bodies, that way I can select each body individually in a static analysis and get the average stress for that specific section. What process would be best for going about this, and would Spaceclaim or Design Modeler be more suited to this task?
March 23, 2022 at 4:27 amKeyur Kanade
Ansys EmployeeYou can use SpaceClaim or DM.
You will need to split the bodies are need. Please go through help manual for more details Also check few tutorials on the same.
Regards Keyur
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2688
2138
1349
1136
462
