April 30, 2022 at 6:27 pm
AaronW
SubscriberThis is the first time i've had this problem, my simulations before have been fine in terms of smoothness but it has been a while since I made one. What do I need to tweak in the analysis settings to get a smoother FPS for my results? Currently I get around 4 frames as my result, leading to very short and choppy results. I have a lot of steps and output points, but that doesn't seem to be helping. The simulation is just a simple armour penetration sim.
Here are my current analysis settings and a video of the simulation, to show the issue
May 4, 2022 at 9:22 pmChris Quan
Ansys EmployeeYou need to modify the parameters in Output Controls under Analysis Settings.
Save Results on -> Result Number of Points should be changed from 5 to 100 or more. Otherwise, you only have 5 results points in Graph for animation. If you have 100 results, the animation will be much smoother and less likely miss any peaks.
Save Restart Files on -> Restart Number of Points is used to restart the simulation. The default is 5. This means that if a simulation is interrupted before reaching the End Time, you can restart the simulation from the last saved restart file. You don't have to restart it from the beginning.
Use of multiple load steps won't increase the number of results saved. This behavior is different from what you have experienced with the MAPDL solver.
Viewing 1 reply thread- The topic ‘How do I get a smooth simulation result in terms of FPS?’ is closed to new replies.
Trending discussions- Maximum Time Step
- Error 20211 (STR+211) while 2D impact analysis
- ls dyna has no solver
- LS-Dyna Prestressed
- Whereabouts of the LS-DYNA program manager
- License error : NO SUITABLE FEATURE FOUND
- Total Contact Force and Contact Pressure
- Contact not working in Ls-Dyna and Ls-Dyna ACT (WB)
- Element direction..
- TIED_CONTACT for Shell Elements – Gap between Shell-Shell and Shell-Solid
8808
4658
3151
1680
1470
