February 28, 2017 at 9:18 am
Nikita
Ansys EmployeeHow do I get geometry instances in ANSYS Mechanical from ANSYS SpaceClaim?
September 29, 2017 at 11:53 pm
pgl
Ansys EmployeeANSYS Spaceclaim uses components for linked geometry.
When copying in ANSYS Spaceclaim, if you copy bodies, they are independent. If you COPY components, they are linked. So when using the move with CTRL key, you have to select the component, not the body. As far as patterns, these will be linked whether you copy bodies or components. But if you do select only bodies, then it will create components and move the bodies into components. So it still uses components to establish the linked behavior.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1347
1118
461
