May 10, 2022 at 1:38 am
luandersoncosta
SubscriberHi guys, i'm a newby at Ansys and I'm facing a problem when I try to insert a new material "Nitinol" on Ansys (see the picture found attached below)
Could anyone help me with this "Es" data?
May 10, 2022 at 8:22 amSurya
"Es" is a Superelastic constant that represents the elastic modulus of the full martensite phase for the Nitinol alloy. Hope that clarifies.
Thanks Surya
How to access the ANSYS Online Help ÔÇö Ansys Learning Forum
Rules & Guidelines ÔÇö Ansys Learning Forum
Viewing 1 reply thread- The topic ‘How do I get Nitinol engineering data?’ is closed to new replies.
Trending discussions- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3153
1680
1470
