Discovery Import
Discovery Import
How do I hide a faceted part?
    • chan.ewen
      I have an assemly that has multiple parts. I was able to set up the physics relatively okay (it isn't entirely correct because I have non-linear material properties for it, but I realize that this is a limitation of the software right now and that's fine), but when the structural solution has completed, I want to be able to look on the part that is inside, in the assembly, and I was able to hide the geometry, but I can't figure out how I can hide the faceted representation of the parts that was used for the analysis.
      Is there a way to do that?
    • chan.ewen
      P.S. I don't want to use the clipping plane. I want to be able to see ONLY the results for the part that I am interested in.
      • Brian Bueno
        Ewen
        At the moment this is not possible.  The only option is to use the clipping plane
      • chan.ewen
        BBueno_ANSYS
        Thank you.
