How do I import mm dimension from ICEM to FLUENT
    • CFDGer
      Hello,ni have the following problem: In ICEM I created a geometry in [mm] (ICEM->Settings->Model/Units->Millitmeters).nThen, when I look at my solution in Fluent Post the length of my geometry has the same value (130) but with the unit [m].How do I import the length units from ICEM to FLUENT correctly?nThanksn
      Don't, in Fluent you'll see a scale button, read the mesh into Fluent and then scale it. I never scale anything in CAD/meshing and always alter dimensions in Fluent as needed (mm to m, mm to inches etc). n
    • CFDGer
      Thats a smart idea, thank you Rob!n
