December 21, 2022 at 2:49 am
marhark92
SubscriberI am conducting FEA on burial fish skulls. I was told to do some type of meshing analysis to determine the appropriate meshing size. However, I do not see a function under the meshing tab in Mechanical. Can someone please help where to find this? I would appreciate it. Thanks!
December 21, 2022 at 1:25 pm
bhagwantP
Ansys EmployeeHello marhark92,
What type of analysis are you performing? You can check for mesh convergence study.
- Perform chosen analysis for several different mesh sizes.
- Notice where high deformations or high stresses occur, perhaps it is worth to refine mesh in those regions.
you may find bellow articles useful to get more detailed idea:
Thanks
Seems above link is not working.
Reposting link path: Specifying an Appropriate Element Size for Stress Analysis — Lesson 1 - ANSYS Innovation Courses.
Thanks
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2706
2146
1357
1144
462
