How do I know whether the convection is laminar or turbulent?
    • Karthik R
      Administrator
      I have a static heater warming up a room how do I know whether the convection is laminar or turbulent?
    • prajput
      I am assuming that your case is purely natural convection. In that case the Rayleigh Number would probably be your answer. However, the Rayleigh Number would inform you whether the boundary layer that forms on the heater would be laminar or turbulent. Typically transition happens when Ra = 10^9.
    • Karthik R
      Administrator
      Oh, I see. I found that the Rayleigh number is Ra = Gr*Pr. What are Gr and Pr?
    • prajput
      The Grashof number is the ratio of the buoyancy forces to the viscous forces:
      Gr = [g*beta*(T_s - T_infinity)*L^3]/nu^2
      where
      g is the gravitational acceleration
      beta is the thermal expansion coefficient
      T_s is the surface temperature
      T_infinity is the free-stream temperature
      L is the characteristic length
      nu is the kinematic viscosity
      and the Prandtl number is the ratio of the momentum diffusivity to the thermal diffusivity:
      Pr = nu/ alpha
      where
      alpha is the thermal diffusivity
Viewing 3 reply threads
