How do I model a spherical bridge bearing
    • Sam Ho
      I am trying to model a spherical bridge bearing using spherical joints and a frictional contact. However, I couldn't get a solution as it never converges.
      Does anyone know how to model a spherical bridge bearing? Does anyone have experience/tutorial/examples of spherical joints?
    • Sampat Kumar
      Hi Sam,
      I have attached some tutorial links for the spherical joint that might be helpful to you.
      https://www.youtube.com/watch?v=Kbklvc9Psss&t=585s
      https://www.youtube.com/watch?v=kkYLar2etDg&t=1096s
      You can also follow the Ansys help document for a detailed explanation of the spherical joint.
      Joint Types (ansys.com)
      The following forum thread is somehow related to the spherical joint, which is why it's attached here.
      https://forum.ansys.com/forums/topic/how-can-i-apply-friction-on-spherical-joints-in-rigid-dynamics/
      If these attached documents don't help you, then you can also explain the problem in detail.
      Sampat
