February 10, 2021 at 2:05 am
far29
SubscriberHello, I am modeling the effect of snoring related vibrations on carotid atherosclerosis promoters and need to account for the frequency dependent material properties for the viscoelastic arterial wall. Any idea how to integrate the frequency dependent properties on ANSYSn -
February 11, 2021 at 10:47 am
1shan
Ansys EmployeenYou can define the material elastic and damping properties as being frequency-dependent (using TB,ELASTIC and TB,SDAMP) for a harmonic analysis based on a Variational technology method. Please check the help documentation 15.4. Harmonic Analysis (ansys.com) (subsection 15.4.6) specifically the command HROPT (ansys.com).nLet me know if it helps.nnRegards,nIshan.nhttps://forum.ansys.com/discussion/3978/how-to-access-the-ansys-online-helpn -
February 11, 2021 at 10:20 pm
far29
SubscribernThank you for the information. I need to couple the harmonic to fluent, however I couldn't find anything about this online. Any way I can do that? Can it be done with external data transfer? The goal of my project is to model the snoring vibrations in harmonic as well as the frequency dependent material of the viscoelastic arterial wall and then run the simulation of fluid where I would model the pulsatile blood flow and get outputs such as wall shear stress in fluent. n
- How do I make a chart with multiple material parameters on y-axis?
- Invalid Assignment error
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- How to add SN curve for new material in Fatigue analysis?
- ANSYS 19.0 with Additive Manufacturing Extension
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- Ansys material damage
5364
3363
2471
1310
1018
