How do I normalize my S21 to value at my lowest frequency
    • tschrans
      Embarrassed to ask, but I want to create a plot of S21, where it is normalize to a value at my lowest frequency. There doesn't seem to be a simple way of doing that, and I've tried.nnIn the competition, ADS, I would simply define S(2,1)/S(2,1)[1].nHere, in circuit designer it doesn't recognize any types of brackets after the S parametern
    • Praneeth
      Hi Array,nKindly make use of the range function tab present on report dialogue window as shown in the following image.nYou can select the YAtXmin or the YAtXVal functions to get the desired value for your to normalize.nAll the very best.nBest regards,n
    • tschrans
      Thank you that works But seems to need a lot of manual intervation.n
    • AndyJP
      >manual intervation.nsorry, support for Cortana is not implemented yet. you need to type functions() manuallyn
    • tschrans
      @pmunagenRange functions don't seem to be available when defining output variable.n
Viewing 4 reply threads
