How do I obtain the wall function value for my udf?
    • newbie123
      I need to obtain the wall function value for the eddy viscosity udf. To clarify, I am not asking how to implement the wall function udf but I need the value of the wall function calculated from Fluent as an input for the eddy viscosity. Thank you
    • DrAmine
      Which Value?. Why do you need that?
    • newbie123
      Thanks for the response. I need the wall damping function f_{mu} for mine case. I need it as an input for my eddy viscosity model.
    • DrAmine
      Which f(mu) Which turbulence model / near wall approach are you using?
    • newbie123
      I wanted to use the default one provided by Fluent. Otherwise I will use Launder-Sharma wall damping function.
    • DrAmine
      You cannot access any of these functions.
    • newbie123
      Is there a reason why I cannot access those? Even for fully licensed Ansys?
    • DrAmine
      Not exposed for general use. If you now you are kind enough and tell me with a picture where you highlight the term you want to use I will maybe provide more info.
    • newbie123
      May I ask what do you mean by "tell me with a picture where you highlight the term you want to use"? I just need to sub in the f_mu value as one of the input for the eddy viscosity udf in Fluent. I don't really need the f_mu formula used by Fluent and I just need the f_mu value calculated by Fluent as one of the input in my eddy viscosity udf for k-epsilon model.
Viewing 8 reply threads
