3D Design
3D Design
How do I open an ANSYS INPUT (.ans) file with workbench?
    • saisacco
      I recently obtained a CT scan in the format of an .ans file and I am unsure how to open it. I understand It is an input file but for which of ANSYS's programs? Is it possible to convert it to a parasolid or some other format that would be easier to put into workbench geometry? Any help would be greatly appreciated.
    • Keyur Kanade
      Can you try SpaceCalim.
      I do know we can read scanned data or faceted data in SpaceClaim, but not sure about .ans file.
      Try it and let us know.
      Keyur
    • Keyur Kanade
      Also please check if you can get some other format like stl or vrml.
      Keyur
    • Rohith Patchigolla
      Try importing the file via MAPDL, where you can write out a cdb file, which can be imported into Workbench via External Model, which can then be connected to Static Structural (for example).
      Best regards,
      Rohith
    • saisacco
      @kkanade: If I open the file in SpaceClaim it says unknown file type.
      @rgpatchi: It tells me that it does not recognize the Begin Command and then does nothing. I am unfamiliar with that program so I may be missing a step.
      Thank you both,
      Stephen
    • Keyur Kanade
      Is it possible to get data in some other format like stl or vrml?
      Many scanned geometries come in stl format. So you may get it.
      Keyur
      Hello Stephen,
      Did you try in ANSYS Classic, File --> Read Input From?
      Best regards,
      Rohith
Viewing 6 reply threads
