September 7, 2023 at 11:30 am
Caleb Wood
SubscriberI am modelling a FSI problem and am having an issue with placing the Lagrange structure (steel H piles in this case) into the Eulerian elements (water in this case). The issue is if I model the piles directly in to ALE mesh and assign a coupling contraint between the pile elements and the water elements, it creates an instability and sends the water flying in all directions, which is definitely a non-physical behaviour. Note that this does not occur at t = 0 sec, but rather after some time has elapsed (say 0.5 to 1 seconds). Does anyone know how to correct this issue? Thank you.
September 8, 2023 at 1:16 pm
Ram Gopisetti
Ansys EmployeeHi,
Leave the piles as Lagrange and use water to ALE then use Constrained Lagrange in solid card and check with DIREC parameter =3 control ILEAKĀ
cheers, RamĀ
Computational Fluid Dynamics (CFD) helps engineers design products in which the flow of fluid components is a significant challenge. These different use cases often require large complex models to solve on a traditional workstation. Click here to join this event to learn how to leverage Ansys Fluids on the cloud, thanks to Ansys Gateway powered by AWS.Ā
Earth Rescue ā An Ansys Online Series
- Explicit dynamics ERRORS
- explicit dynamics
- turning simulation
- Monte Carlo Simulation
- How to solve Energy error too large
7658
4468
2957
1433
1322
Ā© 2023 Copyright ANSYS, Inc. All rights reserved.
