Tagged: command-prompt, fdtd, licensing, lumerical, parametric-sweep
March 15, 2022 at 8:29 am
jorikvandegroep
SubscriberFor a parameter sweep I would like to run my files sequentially from the command prompt using lumericals run license. I tried the steps described here: Ansys Insight: Running Lumerical FDTD simulations sequentially — Ansys Learning Forum .
However, when using the following command
D:file path>"C:Program FilesLumericalv211infdtd-run-local.bat" -t 2 -n 16 *.fsp
I get the error: The system cannot find the path specified.
I thought the problem was that it could not find the batch file from D:, because the file is located on C:, but when I move them to the C-disk it does not make a difference.
What is it that I am doing wrong?
March 15, 2022 at 6:39 pmLito Yap
Ansys EmployeePlease check the "version number/path" to the one installed on your computer. And run the command from the folder/location of your simulation files.
cd
"C:\Program Files\Lumerical\\bin\fdtd-run-local.bat" -n 16 *.fsp
- Error on Lumerical device
2630
2110
1335
1110
461
