June 1, 2021 at 10:11 pm
anmolb18
SubscriberHi,
I am currently working on a project for which I have to create a transient conjugate heat transfer simulation. I have a 3-dimensional geometry made from steel that is at a high initial temperature and I would like to simulate this geometry be cooled down by airflow from an external fan. I would also like to monitor the temperature distribution of the geometry as a function of time and visualize the airflow around it.
It is my understanding that in Discovery, conjugate heat transfer problems can only be solved in the "Refine" mode, but this mode doesn't seem to support time-dependent calculations (please see attached photo).
Am I missing something or am I approaching the problem incorrectly? I'd appreciate any support, guidance and advice!
Thanks!
June 2, 2021 at 6:24 am
Naresh Patre
Ansys EmployeeHello Anmol Bhatia
As indicated in the message, time dependent conjugate heat transfer simulation is currently not available in Discovery Refine mode. You can perform a steady state analysis to visualize the airflow and the temperature distribution in the model. You won't be able to monitor the temperature distribution of the geometry as a function of time.
June 2, 2021 at 4:15 pm
anmolb18
SubscriberNaresh Patre Thanks for the clarification! Are there any other tools you recommend that would allow me to do this?
June 3, 2021 at 7:33 am
Naresh Patre
I think Ansys Fluent should have this capability, although not sure.
- Copy user settings to new release
- Electric Heating – Ansys AIM
- problem to access on the spaceclaim help
- Discovery Getting Crashed
- Dwg export error
- Critical error
- BUG to correct is important
- Error messages running solver
- Discovery Live freezes with multiple load cases while topology optimization
- Unexpected graphics error
3648
2534
1745
1226
578
