How do I solve negative cell volume mesh problem in my FSI simulation?
    • dxc200018
      I'm doing an FSI simulation on a breast pump . I'm getting a negative cell volume mesh in the fluid domain. I've tried shrinking the fluid domain mesh and decreasing the time step size in the fluid simulation, but the error is still present.
      What's the best approach to resolving this?
    • Galvankoehler
      I read your question correctly and I told it to my elder brother because they have knowledge about FSI simulation soon as I get the best answer, I will tell you here https://forum.ansys.com/discussion/39840/how-do-i-solve-negative-cell-volume-10eloto
    • Karthik R
      Administrator
      How did you set up your moving and deforming meshing? Also, is this a completely unstructured mesh? Please share some screenshots so we can understand.
      Thank you!
      Karthik
      • dxc200018
        Thanks, I replied in my other comments. Any general tips for my approach?
    • dxc200018
      Its an unstructured mesh. Here are some screencaps using the solid domain , fluid domain and dynamic mesh
Viewing 3 reply threads
