February 28, 2017 at 9:25 am
Nikita
Ansys EmployeeCan I use the Wrap around target tool to take planar curves or text and wrap them onto planes, cylinders, and cones?
September 18, 2017 at 10:19 pm
pgl
Ansys EmployeeThe Wrap around target tool allows you to take planar curves or text and wrap them onto planes, cylinders, and cones...
You may choose a surface target or establish a direction for the wrap. Curves can be wrapped onto geometry with per-existing imprinted wrapped curves. Surfaces may be used for wrapping, however only the surface edges are used to wrap around the target.
To wrap a curve, text, or a surface around a target object: >Click the Project tool >Check ON the Wrap around target option >Click the curve, text or surface you want to wrap >Click the Select Direction tool guide and choose a direction, you will see purple lines on the target as a preview >Click the Complete tool guide or press the "Enter" key
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2726
2156
1359
1150
462
