July 8, 2019 at 1:55 am
h395523899
SubscriberAfter I did the fluid-solid coupling simulation, I wanted to check the average flow at the outlet of the model, but I didn't find where to set it
July 8, 2019 at 8:09 am
DrAmine
Ansys EmployeeDo you want to have averaged quantities at the outlet? Please check the Calculator tab?
If you are talking abut mean values gathered over certain time then you need to enable that in Fluent or CFX from the beginning or use a CFD-Post script to create this averaged quantities which could be then visualized like any normal variables.
July 13, 2019 at 12:33 am
Raef.Kobeissi
SubscriberCfd post will give you the average pressure for any surface you create. Outlet bc is a predefined surface so you shoul be able to check that in calculator tab.
3862
2639
1859
1254
604
