January 20, 2021 at 7:30 pm
vibrachid
Subscriberi want to calculate the starin modal energy using ansys workbench.
is the potential energy and the kinitic energy the strain modal energy ?.
I carried out the modal analysis, afterwards I carried out the harmonic analysis (solution) and under the harmonic analysis tab I calculated the potential energy + kinetic energy and the result is zero (potential energy + kinetic energy) = 0 on the whole body, why? where did I make the mistake ?.
January 20, 2021 at 11:14 pmpeteroznewman
SubscribernRead this article: https://medium.com/swlh/energize-your-ansys-dynamic-mechanical-analyses-b94c58da9a30nIt was written by and posted in this Discussion: https://forum.ansys.com/discussion/comment/96298#Comment_96298nYou got zero because you did not turn on Volume and Energy in the Output Requests. nENERGYPOTENTIAL alone is the Strain Energy.n
Trending discussions- Solver Pivot Warning in Beam Element Model
5242
3299
2469
