How do we restart a job from windows command prompt line after it failed due to an error?
    • uttam60
      Hello everyone,
      I am currently testing the launching of ANSYS analysis using a windows command line. I had recently run an static analysis that ran for several hours on my computer but failed due to an element error. The error along with restart information can be seen below.
    • Ashish Kumar
      Forum Moderator
      Please see if the following link helps:
      5.8. Restarting an Analysis (ansys.com)
      Regards Ashish Khemka
    • Chandra Sekaran
      You need a .rnnn file to restart. The command for restarting will be something like below:
      /solution
      antype,,restart ! start from last time point
      ..... ! apply/modify any loads or solution controls
      solve
      finish
