March 27, 2021 at 12:55 pm
marcusbrady46
SubscriberI want to also be able to vary the ratio of the materials in property in Static Structual if possible please.n -
March 30, 2021 at 1:39 pm
Govindan Nagappan
Ansys EmployeeIf you are modeling composite layers, you can right click on Geometry in the tree and insert Layered section. You can apply layers to a surface body. In the worksheet, you will be able to specify thickness, fiber angle, material for each layernSee help: Specifying Surface Body Layered Sections (ansys.com)nYou can also use ACP Pre to build a composite lay-upnnIf you have solid model and you are trying to assign two different materials to select regions of the solid, you will have to use command objects or modify geometry and split it into two partsn
Trending discussions
Top Contributors
2630
2110
1335
1110
461
Top Rated Tags
