March 8, 2021 at 9:58 pm
zedstomper
SubscriberOur team for a school project has created a mixing tank. We want to create a rotational zone. We understand this means subtracting the impellar from the tank with a boolean function. But we cannot select the rotational zone at all, only parts of the impellar and the whole vessel. How can we select and create this cylinder/rotational zone as a body part. I believe it was done with a extrude function. Thank you, below is a picture.
March 9, 2021 at 3:51 amKeyur Kanade
Ansys EmployeeDo you want to select the inner body? You can select in the structure tree. Or you can click in the graphics window and you can find selection helper at lower left corner. nnPlease go through help manual for boolean. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
March 9, 2021 at 1:06 pmzedstomper
SubscriberDo you want to select the inner body? You can select in the structure tree. Or you can click in the graphics window and you can find selection helper at lower left corner. https://us.v-cdn.net/6032193/uploads/XYFHIEKYMMH3/image.pngPlease go through help manual for boolean. Regards,KeyurHow to access Ansys Online Help DocumentHow to show full resolution imageGuidelines on the Student CommunityHow to use Google to search within Ansys Student Communityhttps://forum.ansys.com/discussion/comment/109939#Comment_109939
nWere aware of this part but it is not showing up for selection in that tree and we are aware of how use the boolean operation already.nViewing 2 reply threads- You must be logged in to reply to this topic.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2610
2088
1321
1108
459
