November 28, 2020 at 7:14 pm
Abelardo
SubscriberDear ANSYS forum members and readers,
I am trying to do a Tension study of a bogie for my bachelors thesis. The main idea of the thesis is to compare the results from utilizing structure steel and compare it to the results that I get when using Carbon fiber epoxy.
The problem arises at the moment I try to import the Mesh from the ACP to static structure.
When clicking mesh in static structure I keep getting this error and I am not sure why I get it. There is always an issue when I try to mesh the structure and I am not sure why.
November 30, 2020 at 5:55 pmViewing 1 reply thread- You must be logged in to reply to this topic.
- A solver pivot warning or error has been detected
8762
4658
3151
1678
1456
