February 15, 2021 at 4:01 pm
CraigSneddon
SubscriberI am doing an AM simulation on workbench which only works with body fitted Cartesian mesh for some reason.nAnyway I have tried numerous methods and times to refine the mesh using sizing etc and they do nothing. Comes up with tick but mesh is unchanged. Only thing that works is reducing element size for whole model but this make CPU time far too highnI just want to refine high stress/strain concentration areas not the whole part. Does anyone know how to do this? (with body fitted Cartesian)n -
February 16, 2021 at 2:40 am
Keyur Kanade
Ansys EmployeeCan you please upload some images to explain this better? nPlease check nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn -
February 16, 2021 at 10:26 am
CraigSneddon
SubscriberScreenshots won't show anything but I will try to explain better:n1) The only method of meshing that allows an AM simulation to solve in workbench is a body fitted Cartesian mesh (all others such as body sizing etc results in errors)n2) I am wanting to refine this mesh as my simulation is not converging and solve time is already 12hrs +n3) I am only wanting to refine in the corners where high stress/strain regions are present n4) I have tried a number of the mesh tools such as edge sizing to refine my mesh however these do not have any affect unless I suppress the body fitted Cartesian. It is like the body fitted Cartesian overwrites any other mesh sizings/parametersn5) This leaves me with only being able to change the element size for the whole specimen which I do not want to do because of the large solve times involved with much greater number of elementsnDoes anyone know how to stop body fitted Cartesian overwriting all other mesh types? Or how to refine a body fitted Cartesian mesh (other than just reducing element size for full part)?n -
September 21, 2022 at 2:12 pm
bruno vanderschelden
SubscriberI am facing the same problem, did you found any solution for this problem?
- check element type
- Meshing Error
- Error in meshing
- How to resolve Mesh Failure
5290
3311
2469
