3D Design
3D Design
How do you use ProjectPointToFace in spaceclaim scripting
    • Matthew Mavis
      I'm trying to fully script a process in ansys spaceclaim that needs to be written fully in python with no spaceclaim meta data. I'm trying to project a point at the center of mass of a plate to the midsurface face below it then use that point to get the face normal at that point. I have looked through the scripting API document for v21 and have found FaceItem.ProjectPointToFace but I can't seem to access it when using face objects defined by index and not smart variable. Is this intended or am I missing a step to convert a selection/faceselection into a FaceItem?
      Thanks for any help,
      Matthew
    • Aniket
      Can you please explain your requirement with some images? Also, try to add code snippet that you are using.
      -Aniket
