March 4, 2022 at 9:01 am
Margo2018
SubscriberGood afternoon, I have a distributed load - q.
March 4, 2022 at 6:57 pmHemantChauhan
Subscriberif the geometry is made of lines as the beam model you can apply q*l as the load for the beam model by selecting the line and it will distribute and you can also use line pressure
If you modeled your beam with surfaces then it is correct and also you can divide the total load by the area of the surface and that magnitude pressure you can apply to the surface which will be normal to the surface.
December 31, 2022 at 11:59 ambhagwantP
Ansys EmployeeHello HemantChauhan, thanks for your answer.
@Margo2018, you can refer our help manual for more details.
Thanks
2524
2066
1285
1096
459
