How does Mapdl’s data be imported into workbench transient structural?
    • h395523899
      I want to perform fluid-structure coupling, but the structural analysis part needs to be analyzed with Mapdl.
      I want to use the FEM module for structural data transfer.
      But how does the structural module share the model with fluent?
    • Sandeep Medikonda
      Have you tried using External Data?
      Also, why in MAPDL?
      Sandeep
    • h395523899
      Thank you for your answer
      1. I am not familiar with the role of External Data, can show the data transfer connection diagram.
      2. Use Mechanical apdl because it can be written in code, and my partner is familiar with the classic Mechanical apdl operation. And I am only familiar with the operation of fluent.
      My question now is whether Mechanical apdl can independently perform fluid-solid two-way coupling.
      If not, can I pass the Mechanical apdl data to the workbench platform and fluent through the system coupling module for fluid-solid two-way coupling.
      If the latter is possible, the biggest problem is how to keep the data of Mechanical apdl on the transient structural.
