3D Design
3D Design
How does one measure the element size of a auto generated convergence mesh
    • michaelamos
      I have an initial mesh, but by running the solution for a convergence, the mesh changes. For reports I need to get the element size of the new mesh. Is this possible? n
    • peteroznewman
      Not that I know of. Don't use a Convergence tool on the Stress result. Change the mesh size using mesh controls and do the convergence manually for a report. You can use the automation of the Parameter feature and make the mesh size an input parameter and the maximum stress an output parameter and let the Table of Design Points tabulate the convergence of element size vs stress and plot a convergence graph.n
