How fluent deal with stress tensor and pressure gradient in momentum equation of porous media?
    • Weiqiang Liu
      Hi all,
      I have some confusions on how fluent deal with stress tensor and pressure gradient terms in momentum equation of porous media. Below is my control equation of steady-state.
      Forum Moderator
      Check the manual, but I suspect it's either in the porous media section or not covered in detail. Molecular viscosity is a material property, so that will depend on what you've set. n
    • Weiqiang Liu
      Check the manual, but I suspect it's either in the porous media section or not covered in detail. Molecular viscosity is a material property, so that will depend on what you've set.https://forum.ansys.com/discussion/comment/99307#Comment_99307
      ok , thanks for the suggestion!nBest regardsnweiqiangn
  • The topic ‘How fluent deal with stress tensor and pressure gradient in momentum equation of porous media?’ is closed to new replies.
