July 6, 2022 at 7:47 pm
Parsa
SubscriberHello,
I am calculating attenuation (real part of Gamma) in a transmission line with HFSS. But the results are not in range with what I calculate from ABCD matrix.
I want to know how HFSS calculates GAMMA?
I am using S-parameters calculated from HFFS and plugging them into the following equations to calculate Gamma:
Thank you.
July 20, 2022 at 11:41 am
Praneeth
Ansys EmployeeHi Parsa,
The approach you are using is correct. Please verify your calculations one more time.
Best regards,
Praneeth, Ansys.
- Maxwell, HFSS or Q3D?
- Error
3744
2573
1809
1236
594
