Ansys Products
Ansys Products
How I am created grid (net) in this cage?
    • Basu Bhowmick
    • Ashish Khemka
      Hi Basu,
      Please see if the following link helps you:
      Beam and Shell Modeling with ANSYS Mechanical [Tutorial] - Bing video
      Ashish Khemka
    • Basu Bhowmick
      No. This is not useful sir. I want to know how a net create in ansys hydrodynamic.
    • Mike Pettit
      To model a net like this for a hydrodynamic analysis, you should either:
      • Create the net geometry explicitly in the geometry editor (SpaceClaim), using an arrangement of several line bodies. The viscous drag and added mass contribution of the net in the hydrodynamic analysis is accounted for by Aqwa as it solves the Morison equation for each line body element.
      • Or, model the effect of the net by adding a number of Morison disc elements directly in the Aqwa Workbench editor. The disc normals, added mass coefficients and drag coefficients should be chosen to match the real hydrodynamic effect of the net.
      I hope this helps.
      Mike
Viewing 3 reply threads
