July 25, 2019 at 11:00 am
prashantsaini9997
Subscriberi have .dat file of heat flux which i got from a code. i want to apply this heat flux file on the surface of wall. so please anyone guide me how i can apply heat flux file (.dat) in the Ansys (Fluent).
July 25, 2019 at 4:04 pm
SubscriberWhat code wrote the .dat file?
What units are the values in the .dat file written in?
Do you have the geometry used by the code to generate the heat flux?
Is the heat flux a single value on each node (steady state) or is it transient?
What kind of Fluent model are you building?
July 26, 2019 at 5:03 am
prashantsaini9997
Subscribersir i have developed Monte carlo ray tracing code. and also incorporate it with self developing sub routine program which will generate the .dat file. and in .dat file there is values of x (meters), y (meters), z (meters) [co-ordinates], angle (degree) [circumferential angle of tube (0 to 360 degree) and heat flux (Watt per meter sqaure).
yes i have the geometry dimensions which i am input in the code.
.dat file having heat flux values of whole tube. tube having length of 8 meters and .dat file having values of heat flux from 0.1 meters up to 8 meters.
Sir, i want to apply this .dat as a heat flux on the surface of simple wall to calculate the its effect.
July 26, 2019 at 9:47 am
Ansys EmployeeRead up on boundary profiles, you may need to reformat your dat file to read into Fluent. Note, Fluent will interpolate data so you may see some differences between the input data and what is used depending on the relative resolution of the file and surface mesh.
July 26, 2019 at 10:22 am
Ansys EmployeePlease do not post questions in multiple sections of the Community: https://forum.ansys.com/forums/topic/how-i-can-apply-the-heat-flux-file-on-the-surface-of-wall-in-ansys-fluent-1/
2630
2104
1329
1110
461
