December 9, 2019 at 12:23 pm
atulsingh92
SubscriberHello,
1 ) I wanted to know how is the nusselt number calculated in Fluent?
If I understand correctly, it should be Nu = hx D / k, however, if there is a comparaison to be made with equations such as Dittus Boelter and/or Sieder Tate, how do we know, should we compare with the former or the later?
2) HMT textbook suggests the hydrodynamic turbulent BL develops after x/D > 10, where x is the length of the length in question.
Now if I have a pipe length smaller than this value (periodic unit of a pipe, non axis symetrical because of helical cut around its periphery),
how then, would the nusselt number in fluent indicate a correct value along its wall, or it doesn't, and a full pipe simulation is recommended instead? -
December 9, 2019 at 3:47 pm
Ansys EmployeeIf you look in the User Guide most (all?) of the post processing functions are defined: Field Function Definitions chapter.
5162
3275
2451
