July 15, 2018 at 7:57 pm
longcwang3
SubscriberHi, I am now simulating the boiling in vertical annulus using Eulerian multiphase model and RPI boiling model. I set the secondary phase diameter (vapor) diameter to 'boiling-dia', but I can't find how it's calculated from the User guide. Can anyone show the equation to calculated this diameter?
July 16, 2018 at 10:44 am
July 16, 2018 at 1:50 pm
July 16, 2018 at 4:42 pm
July 16, 2018 at 4:53 pm
longcwang3
SubscriberThanks for your reply, Karthik,
So this bubble diameter is exactly the same as 'boiling-dia'. Does the wall lubrication models use this model as well?
July 16, 2018 at 5:26 pm
Karthik R
AdministratorHi,
Yes, the wall lubrication models in RPI boiling model (Antal et al., section 17.5.8.1.1) uses these bubble diameter definitions. I'd recommend you go through the theory guide for additional details. Hope this helps.
Good luck with your model.
Best Regards,
Karthik
2688
2138
1355
1140
462
