August 2, 2023 at 12:15 pm
jiangtao.lu
SubscriberI have a multiphase problem, and am checking mass- and volume-weight average definition.
In Theory Guide, mass average is below, and explitcitly say rho_i is the mixture density. In this case, V_i is clearly to be the total volume.
the volume aveage is blow. Is V_i the total volume also? If so, I do not understand...
If we consider a variable in phase k in a multiphase problme. Shouldn't we consider the phase fraction? Namely the following equations?
Even if we take one step back for the average of the total volume, the phase fraction should still be in the numerator, isn't it?
August 4, 2023 at 2:50 pm
Federico Alzamora Previtali
SubscriberHello,
variables with subscript _i are cell values, so you are summing over the total number of cells the corresponding quantities, which give you the total quantities.
Hence, V is the total volume, V_i is the volume of cell i. Finally, rho_i is indeed the mixture density, for cell i.
August 4, 2023 at 5:35 pm
jiangtao.lu
Subscriberthanks. Now the definition is clear, then my point is such calculation is nonsense, if we do not include the phase volume fraction of cell i for a multiphase problem.
August 4, 2023 at 5:49 pm
SubscriberWhich equations from the Theory Guide are you looking at? If you are referring to Eqs. 26.35 and 26.32 (from 23R1 Theory Guide), then these are general mass weighted and volume weighted averages equations. You are correct to say that for a multiphase problem, the volume fraction of the phase should be included.
August 4, 2023 at 7:44 pm
jiangtao.lu
Subscriberthanks for reply. Yes, I am looking at these two equations in Theory Guide, which are used in 36.2.1.2 Volume Report Definitions and 36.8.1 Generating a Volume Integral Reoport in User Guide.
Thanks for confirming these calculations are invalid for multiphase problems.
August 4, 2023 at 8:34 pm
SubscriberRight, these two equations are general formulations, not specific for multiphase.
7626
4456
2955
1427
1322
