September 8, 2021 at 12:46 am
Weidong
SubscriberIt seems the *Force transducer penalty could output the local pressure on rigid body, but my case does not show good results.
Could you please give me some suggestion about my problem?
Enclosed please find my keyword.
Best regards,
Weidong
September 8, 2021 at 11:37 amAniket
Ansys EmployeeAnsys staff can not download any files on the forum, so if you want to reach a larger audience to get answers from, please insert inline images describing your problem.
-Aniket
April 19, 2022 at 9:11 pmametist91
SubscriberHello Weidong
Did you solve this problem?
May 19, 2022 at 9:04 amWeidong
SubscriberHi,
I still can not solve my problem. when I use the keyword *Force transducer penalty to output pressure, the results of pressure is not good. Could you please give me some suggestion about my problem?
Best regards Weidong
May 20, 2022 at 11:59 pmAndreas Koutras
I tested *CONTACT_FORCE_TRANSDUCER_PENALTY in a *CONTACT_AUTOMATIC_SINGLE_SURFACE between a deformable and a rigid body using the latest SMP version. The results are as expected.
If the contact forces are noisy, it will help if you specify some damping in the contact through VDC. VDC=20 is a common value.
Otherwise, if you can provide some details and pictures of the model and of the results that demonstrate the issue, we may be able to help more.
Viewing 4 reply threads- You must be logged in to reply to this topic.
Trending discussions- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
3744
2573
1799
1236
594
