January 17, 2022 at 12:25 am
agarwa20
SubscriberIs there some way to fix the number of result designs that are generated on optimization like how for sensitivity analysis the number of samples can be fixed. -
August 1, 2022 at 12:34 pm
Markus
Ansys EmployeeHello agarwa20,
the NLPQL is a gradient-based optimization algorithm using by default a central differences scheme. So, you can not specify a fixed number of samples. You find more details in the “Help” e.g. here
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v222/en/opti_multi_disc/opti_multi_disc_single_objective_opt.html%23opti_multi_disc_gradient_based_methodsIf you like to fix the number of samples beforehand, you may choose a nature inspired optimization algorithm like a “Evolutionary Algorithm”. You also find more information in the “Help” on this kind of algorithms e.g. here
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v222/en/opti_ug/opti_ug_opti_strategies.html%23opti_ug_nature_inspiredBest regards,
Markus
- Local Sensitivity and Sensitivities: what difference?
- How many designs are generated while performing optimization using Optislang with NLPQL?
- Optislang workbench add-in
- DesignXplorer vs optiSLang for Workbench CFD Optimization
- Errors about integrate executable into ANSYS Workbench using ACT
- Parameter relationships for Optimization
- ANSYS Optislang
- DOE all design points give the same results as the first calculation
- Parametric study: Batch mode
- Design of Experiment points: Design Exploration
3780
2587
1831
1244
598
