March 22, 2023 at 5:39 pm
Merve Ala
SubscriberI am working on NACA2415 airfoil. I took the points from javafoil application. When I increase the points the trailing edge side's shape (aft of airfoil) becomes deformed. In this image there are 301 points and I can not use less point than that point number in my project. How can I solve that problem? How much point is ideal?
March 23, 2023 at 1:59 pm
Ansys EmployeeI'm not sure what you're asking. If you need 301 points then that's what you need. The geometry limit in Student is because it's to learn the basics, if you need more geometry, mesh or parallel solve you're going to need access to the University Research licences.
5454
3419
2473
1310
1022
