March 12, 2021 at 6:43 am
Sherin
SubscriberI conducted core and copper loss calculation on a high frequency transformer at 1700Hz and at full load condition by applying a resistive load at the Hv terminal.
I have enabled matrix computation in data settings for calculating self inductance and mutual inductance
But when I get result. Inductance found varying wrt time as shown below
March 12, 2021 at 6:07 pmicellb1
Ansys EmployeeHi,nIf your core material has a non-linear permeability, the inductance would change as current varies with time. nMarch 13, 2021 at 4:56 pmSherin
SubscriberBut in transformer we are calculating a single inductance value by conducting SC test. nHere is there any method for getting single inductance valuennViewing 2 reply threads- You must be logged in to reply to this topic.
- Maxwell, HFSS or Q3D?
- Error
2524
2066
1279
1096
459
