March 3, 2023 at 9:49 am
AHMED ATIQ BEN
SubscriberGood Evening everyone,
I am facing a problem and I need your kind guidance.
I have GDS file of 140 GHz 4CH RX in ADS. I need to check the isolation, insertion loss and crosstalk of the input lines.
I imported the GDS in SIwave, define the layout with thickness then export it HFSS 3D EM solver. But all of my circuit elements are not exported properly. Only some portions of it.
Is there anything wrong in my process, or what should I do now?
Please guide me with proper steps how can I import GDS to HFSS and run the 3D EM simulations?
Thank you
N:B: I uploaded two pictures of SIWave and HFSS 3D EM solver -
March 6, 2023 at 8:59 am
Erik Kostson
Ansys EmployeeHi
I would suggest to post this in the Electronics forum.
All the best
Erik
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
3720
2570
1783
1236
594
