Tagged: explicit-dynamics, fluid-dynamics, mechanical, system-coupling
July 28, 2021 at 3:35 pm
bxddstl
SubscriberProfessor, ,I am a novice. I wanted to do a solid and fluid coupling simulation (including gravity, including solid and fluid interactions and solid and fluid deformations) for about ten seconds, using explicit dynamics, but because my computer is weak, I wanted to take the ten second solid and fluid coupling and run it in 0.001 seconds.
So I would like to ask which physical parameters of fluids and solids I need to change, such as changing gravity acceleration to 10000G(because the time become 0.0001)?Or do other physical parameters need to be changed?
I'm not sure. Could you help me?Thank you 。😀
July 29, 2021 at 10:44 amRob
Ansys EmployeeIf you accelerate things you may find you need a smaller timestep to resolve the system. Read up on Courant Number to understand why. You may also need to alter other properties to balance effects, some of those techniques are explained in wind tunnel and water flume best practices.
Ansys Innovation SpaceSimulation World 2022
Check out more than 70 different sessions now available on demand. Get inspired as you hear from visionary companies, leading researchers and educators from around the globe on a variety of topics from life-saving improvements in healthcare, to bold new realities of space travel. Take a leap of certainty and check out a session today here.
Trending discussions- Ansys vof(volume of fluid)
- coupled lng sloshing
- How to simulate the balloon of force in oil
- Simulating the working principle of cylindrical heat pipe with wick stracture?
- Air Lubrication System
- Floating point exception: Overflow
- How can I find more thermodynamic data?
- Variable time stepping method
- What kind of fluids can be assumed to be continuum and what not?
- What is the acceptable Y plus value for a rough wall in SST k-omega model
613
562
220
188
128
Top Rated Tags© 2022 Copyright ANSYS, Inc. All rights reserved.
