June 20, 2019 at 5:24 pm
roytorc
SubscriberI am trying to access cell temperature using "c->temp" which works in Fluent 17.2. However, using the same thing in Fluent 2019R1 gives me 0 output. Here is the code I'm using. Could anyone advise.
#include "udf.h"
#include "stdio.h"
#include "string.h"
#include "stdlib.h"
#define mesh_size 103456
#define Ad 4e21 /* 1/s */
#define Ed 142000 * 4.18 * 0.95 /* kJ/kmol */
#define R 8.314 /* kJ/kmol.K */
DEFINE_INIT(thermal_age_setup,domain)
if(NULLP(user_particle_vars)) Init_User_Particle_Vars();
strcpy(user_particle_vars[0].name, "thermal-age");
strcpy(user_particle_vars[0].label, "Thermal Age");
strcpy(user_particle_vars[1].name, "thermal-age-0");
strcpy(user_particle_vars[1].label, "Thermal Age 0");
DEFINE_DPM_SCALAR_UPDATE(thermal_age, cell, thread, initialize, p)
cphase_state_t *c = &(p->cphase);
if(initialize)
P_USER_REAL(p,0) = 0.0;
P_USER_REAL(p, 1) = Ad * exp(-Ed / R / c->temp);
else if (P_POS(p)[0] < 0.175)
P_USER_REAL(p,1) = Ad * exp(-Ed / R / c->temp);
else
P_USER_REAL(p,0) = P_USER_REAL(p,0) + P_DT(p) * 0.5 * (P_USER_REAL(p,1) + Ad * exp(-Ed / R / c->temp));
June 21, 2019 at 5:23 am
DrAmine
Ansys EmployeeCheck the manual. There was a change in the structure so that you need to tell which phase it is. In an example you can find that. Other way is to find the cell where the particle is located. -
June 21, 2019 at 5:28 am
roytorc
SubscriberThank you for your reply. Could you elaborate more on ' you need to tell which phase it is'. Also, is using C_T(P_CELL(p), P_CELL_THREAD(p)) equivalent to c->temp? I have tried that and I don't think it gave me the same result.
I forgot to mentioned that Fluent 17.2 was in linux and Fluent 19R1 is in windows10.
June 21, 2019 at 6:14 am
roytorc
SubscriberI modified my code to cphase[0] and I think it work now.
However, I ran my previous code on Fluent17.2 (windows10) and got the MPI error while using the same UDF in Fluent17.2(Linux) had no problem. Could you please advise the reason of this circumstance.
June 21, 2019 at 6:17 am
DrAmine
Ansys EmployeeNo I apologize here. Use the latest release and check if it is working.
3670
2552
1751
1226
582
