June 19, 2022 at 2:19 am
shahsav1
SubscriberHello all
With this new platform by ANSYS (ANSYS Innovation), some of the old chats and questions are not accessible. Does anyone know how we can have access to the old questions and FAQs in the current format.
Thanks in advance -
June 19, 2022 at 11:20 am
SubscriberYou can browse the old forum in a read-only mode here: https://forum-legacy.ansys.com/
The search function doesn’t work in the old forum but you can use Google instead.
When you search on Google, type this in front of your search termsite:forum.ansys.comHowever, the links that Google saved are now all broken. What you have to do is copy the link address, then in a new browser tab, paste the address into the URL address bar and type -legacy after the word forum and before ansys.com you should land on the relevant page.
June 29, 2022 at 3:26 am
SubscriberMy answer above was only useful during the transition to the new forum. The old forum no longer exists. The content of the old forum has been copied into this forum.
July 14, 2022 at 8:59 am
plksharma481
SubscriberHi @peteroznewman
Well lots of people is thinking about the same thing, well your answer is useful for all of those including me.
Thanks
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
3744
2573
1803
1236
594
