November 30, 2022 at 7:10 pm
November 30, 2022 at 7:11 pm
vahram.voskerchyan3
SubscriberI can only modify the first row with
set('start cell group', 1);
set('end cell group', 2);
set('periods',1000);
November 30, 2022 at 9:45 pm
Guilin Sun
Ansys EmployeeYou can use this to find all parameters that you can set through script:
?setnamed("EME");
for group span, you can set matrix
span=[1e-05;
3.2e-05 ;
1e-05 ],then
setnamed("EME","group spans",span);
other quantities are similar. Please try.
- Error on Lumerical device
2524
2066
1279
1096
459
