May 29, 2023 at 1:33 pm
May 29, 2023 at 5:08 pm
Amrita Pati
Ansys EmployeeHi Vahram,
You can use the following code to edit the slab mode postions:
setnamed("varFDTD","x0",0.0e-6);
setnamed("varFDTD","y0",0.0e-6);
You can save the test points in a 4X2 matrix (4 test points' x and y co-ordinates) and then use this with the setnamed command as shown below:V = [1e-6,1e-6;
1e-6,-1e-6;
-1e-6,-1e-6;
-1e-6,1e-6];
setnamed("varFDTD","test points",V);
Please let me know if you have any further questions.Regards,
Amrita
- Error on Lumerical device
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Lumerical – error message when trying to open from Linux terminal
7592
4440
2953
1427
1322
