How to accurately model flow separation of air at sharp inlet-edge
    • SU252019
      I currently am trying to obtain a flow simulation result that shows boundary-layer flow separation at a sharp edge, however the contours I generate do not show my intended result. Most of my CFD simulations do not show any or very little boundary-layer activity in the desired region. Is there a specific tool in ANSYS / FLUENT that would help capture the region in a flowfield where flow-separation occurs in a turbulent flow?
      Thank you!
      Can you post images of the solution and mesh? You need to make sure you have everything set correctly: you may not have separation.
    • SU252019
      Correct result I am attempting to replicate
      Correct result I am trying to replicate
      Current progress on my simulation
      For freestream Mach number of 0.2
      Fluid: air, ideal gas
      From what I can see of your mesh you need to review the documentation on inflation and mesh size control: it looks far too coarse to pick up much of anything.
Viewing 3 reply threads
