November 29, 2022 at 4:02 pm
Haaziq Izzadeen
SubscriberI have inflation on 2 edges at 90 degrees to each other, how do I get a square mesh from this without it being skewed? I can't acheive the desired effect with edge sizing and bias since I want a min cell height on both edges and edge sizing does't keep a consistent first layer cell height horizontally. Any pointers?
November 30, 2022 at 11:16 am
Ansys EmployeeDo you have both faces in the same inflation setting? I'm trying to figure out if you have the same number of layers.
November 30, 2022 at 3:45 pm
Haaziq Izzadeen
SubscriberIn the picture attached, I have the same number of layers with the same growth rate and first layer cell height on both edges. The application is treating the two perpendicular edges as 1 layer which I do not want. Instead I want a structured grid with inflation going upwards and another inflation layer going right (so the smallest cell will be bottom left corner and largest will be top right). I do not want to use edge sizing/bias to achieve this because I want to make sure I can specify the exact first layer cell height.
The last picture ive attached is what im trying to achieve
November 30, 2022 at 1:12 pm
SubscriberUse Edge Sizing with Bias to get an orthogonal element shape. Zoom in and manually measure the distance between nodes in the first layer and adjuat the Edge Sizing/Bias until you get the desired first layer thickness.
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2684
2124
1349
1136
461
